4 Strategies to Make Your Production More Efficient in 2021
The start of the new year is a great time to critically take a look at your processes and see how you can improve. Here at FANUC, we have identified four key strategies manufacturers can use to boost their efficiency!
Add Automation
Automation can increase production and efficiency no matter the type or complexity of the manufactured products.  With space at a premium in most production facilities, many job shops look for machine tending robots that are easy to integrate and have a small footprint. FANUC's robots and software make it easy to connect the equipment and improve throughput as well as overall equipment effectiveness. Robot Options allows up to four machine tools to be connected with a robot using just one Ethernet cable.
Use the Latest and Greatest Machining Practices and Technology
Many manufacturers leave performance on the table due to outdated processes and programming. Are you getting the most out of your machining? Now’s the time to look at the advantages in new CNC technology. Because new controls have greater processing speed and can implement advanced algorithms, they can do a lot more for your operations. Moreover, the interfaces have become simpler and more intuitive, so they are easier to use than ever before.
Digitize Your Process
New digital tools are breathing innovation and life into increasingly more areas of manufacturing, including the application of digital twins in the machining industry. Digital twins provide virtualization of the machine, control and manufacturing process.  Digitalizing traditional manufacturing processes have the potential to make operations more efficient by proving out production processes in the virtual world. That means less waste, more efficiency and a more equipped workforce.
Upgrade Your Shop with a CNC Retrofit
Do you have legacy equipment? Running older machinery can have hidden costs, such as taking the time to source and find older replacement controls leading to significantly longer total downtime and production losses. However, scrapping old equipment and starting new, might be too expensive, especially when factoring in tooling, fixturing, rigging and foundation. Plus, new machines may require more training for staff. A CNC retrofit, with new FANUC CNCs, industrial PCs, servos and cabling, can speed up processing and reduce cycle time by as much as 50 percent.
