  5. Kemco Aerospace Automates CNC Machine Tending to Grow Business
Kemco secured an aerospace contract by boosting throughput and efficiency with an unattended FANUC robotic machining and tending solution.
Solution By
Industrial Tool Inc.
Last Updated September 21, 2026
Industrial Tool Inc. Video courtesy of Industrial Tool Inc.
A man wearing safety glasses and a face mask operates a FANUC CNC control panel, with an orange robotic arm visible behind the safety fencing in the background.
https://www.fanucamerica.com/case-studies/kemco-aerospace-manufacturing
Need to integrate automation to stay competitive
Achieve high, consistent standards with a fully autonomous system
Maintain accurate part production, placement, and inspection without manual intervention
Delivery
Increased productivity and efficiency
Proven technology
Standardized training and operations
Machine uptime
Streamlined the “seamless” integration between equipment
Kemco had the opportunity to bid on a large package of work for an aerospace manufacturer and needed to compete with an aggressive quote to win the order.
Because Kemco predominantly uses FANUC controls in their shop, the company brought in Industrial Tool, Inc., a FANUC ASI integrator, to design a truly unattended automated robotic system that would increase throughput and boost efficiency.
As part of the automated robotic cell, a FANUC M-710iC robot, assisted by 3D vision, machine tends a lathe and two mills, all equipped with FANUC 0i-F controls.
The result landed Kemco the aerospace supplier contract because their quote guarantees the delivery of consistent high-quality parts at a cost that was competitive, yet still provided Kemco with an adequate margin.
Dan ladenberger kemco
There are no human touches within the cell, which create a very substantial repeatability in the process of manufacturing. The lack of human interaction with the cell actually creates a substantial amount of quality benefits because you don’t have human error in load and unload.
Dan Ladenberger President – Kemco Aerospace
FANUC is the majority of our shop. It’s great because it’s so widely used in the industry. When we’re looking for new machine operators, it’s nice to know that it’s not a niche market. It helps us to be able to recruit people and bring them in-house.
Delena Haefner Vice President of Operations – Kemco Aerospace
Yellow FANUC M-710iC industrial robotic arm on a gray base, shown against a white background with its long arm extended upward and to the right.
Articulated Robots
M-710iC/12L
The FANUC M‑710iC/12L is a small to medium payload 6‑axis robot model ideal for all applications to handle medium payloads for up to 12 kg.
12 kg
3123 mm
View M-710iC/12L
FANUC CNC Controls 0i MF Plus
0i-MF Plus
FANUC 0i-MF Plus CNC delivers efficient, high-quality milling with reduced cycle times, smooth surface finishes, customizable functions, and flexible HMI.
View 0i-MF Plus
C2050x1346 0 12 S822x540 FJPG Q85 1
0i-TF Plus
FANUC 0i-TF Plus CNC delivers powerful, compact turning control with flexible screens, multi-axis capability, fine surface machining, and reduced cycle times.
View 0i-TF Plus
0i LF Plus Full Panel
0i-LF Plus
FANUC 0i-LF Plus CNC unlocks high-speed, high-precision 2D laser cutting with fast processing, iHMI visualization, and seamless machine integration.
View 0i-LF Plus
Kemco reached out to Industrial Tool, Inc. (ITI), an authorized FANUC integrator, for guidance on integrating automation into their operations. Because Kemco wanted a truly unattended robotics system that could identify and quarantine bad parts, ITI worked with them to integrate FANUC systems into their production process.
Visit Website https://www.industrial-tool.com
Kemco
KEMCO Aerospace
Kemco Aerospace is one of the United States’ largest independent aerospace machining shops with specializations in various aspects of aerospace manufacturing, including prototyping, complex assembly, high-volume machining, and more. With a focus on solving their customers’ most difficult manufacturing problems, Kemco is passionate about integrating innovative engineering solutions to help their customers achieve their goals.
Visit Website
