FANUC Digital Servo Adapter–MODEL B for Motion Control
The FANUC Digital Servo Adapter-Model B is a motion control device that enables the integration of a FANUC servo system with an existing, third-party control. Because a CNC is not built into the Digital Servo Adapter-Model B, a PC-based control or a PLC-based control is required to provide commands. The Digital Servo Adapter-Model B takes an existing motion controller, or something that’s more suited to a PC or a PLC, and allows you to use FANUC servo motors and amplifiers.
Contact a FANUC CNC Motion Control Expert, today.
Contact us
Key benefits of the Digital Servo Adapter-MODEL B:
More options: Take advantage of FANUC’s wide range of servo motors.
Maximum flexibility: Access the many synchronous and multi-amplifiers drive configurations.
Ease of use: Standardize general motor applications on FANUC servo systems.
Improved operations: Have a common platform to assist with maintenance and parts.
Flexible protocol choices: Works with analog commands, HSSB, EtherCAT and POWERLINK.
The Digital Servo Adapter-MODEL B is perfect for many applications, such as:
