- Case Studies
How Pearl Crop Increased Throughput, Improved Safety & Added Flexibility with Robot Rentals
Facing seasonal labor shortages, Pearl Crop automated palletizing with rented FANUC robots, increasing throughput, improving safety and creating workforce flexibility.
How Inland Packaging Exceeded Every Performance Goal with Robotic Packaging
With limited floor space and tight labor availability, Inland Packaging used a custom FANUC robotic cell to cut line staffing in half and surpass key performance goals.
25% Increased Output: How Thogus Transformed Helmet Production with Robotic Drilling
Thogus eliminated a production bottleneck, increased output by up to 25% and improved manufacturing flexibility with a custom robotic drilling system powered by FANUC robots.
Achieving Zero-Defect Aerospace Manufacturing with Automated Grinding and Inspection
Pointe Precision machines mission‑critical aerospace parts with ultra‑tight tolerances. To ensure flawless, scalable precision, they use automation where failure isn’t an option.
Reducing Sanding Time by 50%: RC Industries Uses Automation to Improve Finish Quality
RC Industries improved finish consistency and reduced manual sanding strain by implementing an automated solution with Complete Solution Robotics and Notre Dame’s iNDustry Lab.
Over 10 Times Higher Throughput Achieved Through Automated Inspection
BelleFlex boosted production 10x by automating disc spring inspection with FANUC robots — replacing slow, inconsistent manual checks with fast, precise, and reliable quality control.
Minnesota Food Maker Streamlines Packaging and Palletizing with Fully Automated Delkor System
Mrs. Gerry’s partnered with FANUC integrator Delkor to automate a labor‑heavy packaging line — boosting throughput, cutting labor, and reaching full production in just 10 days.
48% More Throughput: Immediate Results at RMR Solutions
By automating with a FANUC CRX cobot, RMR Solutions boosted packaging output, improved ergonomics, cut turnover, and built a scalable foundation for future growth.
Automated Brake Press Tending Helps Thunder Creek Increase Output and Reduce Labor Strain
With demand rising and manual brake press work posing safety risks, Thunder Creek partnered with The Way Automation to deploy a FANUC R‑2000 robotic cell, improving throughput and consistency.
A Smarter Way to Sand: Gupta Permold Automates
Facing labor shortages and inconsistent finishes, Gupta Permold automated beam sanding with a robotic cell — boosting throughput, improving surface quality, and reducing hands‑on labor.
Cobot Beveling and FANUC Machining Centers Boost Quality and Productivity for Optics Manufacturer
Discover how robotic beveling transformed Sydor Optics’ manual process, freeing employees for higher‑value work while reducing rework and increasing overall throughput.
How Zenni Optical Built a Faster, Smarter, More Scalable Fulfillment Line
Learn how Zenni Optical increased fulfillment throughput by 80% by deploying AI‑powered robotic bagging with advanced vision — cutting manual steps and achieving near‑zero errors.
Painting in Partnership: Regal Finishing Elevates Its Paint Operations with RTSS’ Automation Solution
Learn how Regal Finishing increased throughput by up to 133%, reduced painters by half, and improved first‑run quality with a fully automated robotic paint line.
From Labor Shortages to Longer Runs: How NKM Scaled with Robots
Discover how Northern Kentucky Machine uses robotic machine tending to extend unattended runs, boost productivity, and scale without adding headcount.
Boosting Stone Fabrication Efficiency with FANUC-driven BBM Routers
See how automated stone cutting helped Southern Stone Surfaces achieve precise, detailed countertop cuts while improving efficiency and expanding production capacity.
To overcome skilled welder shortages, Steelway Building Systems adopted robotic beam welding — boosting throughput, redeploying labor, and positioning the operation for scalable growth.
Automating Agriculture: Greenhouse Turns to Robots for Tomato Harvesting
By deploying intelligent robotic harvesters, Westburg Greenhouse reduced reliance on manual labor, improved efficiency, and created a scalable path for greenhouse automation.
Cripps & Sons Woodworking Embraces Automation for Smarter, Safer Sanding
By adopting robotic sanding, Cripps & Sons transformed a labor‑intensive bottleneck — reducing costs, improving finish quality, and scaling production without sacrificing craftsmanship.
How One Company Doubled Output and Improved Employee Satisfaction through Automation
By automating CNC machine loading and unloading, CNC Machine Products doubled production, achieved 100% quality, and freed employees for higher‑value work.
Automated Precision Transfer Machines take Titanium Part Production to Next Level
By adopting CNC rotary transfer machines with robotic tending, Mitotec Precision boosted throughput, improved accuracy, and reduced secondary operations on titanium parts.
Automation on the Move: Saddle Creek Logistics Deploys Pixmo for Smarter, Safer Logistics
To improve dock safety in extreme heat, Saddle Creek deployed an AI‑powered mobile robot to automate unloading — cutting labor needs, increasing throughput, and eliminating unloading injuries.
Grinding Out Results: How A Steel Fabricator Boosted Output & Upskilled Workers
Robotic grinding helped Lawrence Brothers lower rework, save costs, and transform a difficult manual job into a safer, more sustainable operation for its workforce.
Unpacking Efficiency: GNC’s Automated Depalletization Success
Facing DC congestion and labor-heavy depalletizing, GNC partnered with AWL to deploy FANUC R‑2000 robots, smoothing product flow, improving consistency, and freeing employees for higher-value work.
AI-Driven Robotic Depalletizing System Boosts Safety at Book Fulfillment Center
AI-powered robotics transformed Lakeside Book’s depalletizing — beating human speeds, handling mixed-case variability, easing labor strain, and eliminating 45M+ lbs of lifting.
Showing 1–24 of 92 case studies
