  5. FANUC CNCs Drive High-Precision Machining at Lincoln Park Boring Co.
Lincoln Park Boring improved large-part machining with a FANUC-controlled boring mill, enabling tighter tolerances, faster speeds, and flexible operation.
Solution By
Fives logo white3
Fives Group
Last Updated May 15, 2026
Fives Machining Systems, Inc. Video courtesy of Fives Machining Systems, Inc.
Lincoln park boring cover
https://www.fanucamerica.com/case-studies/lincoln-park-boring-company
Transition legacy equipment
Need a solution that delivers on accuracy, repeatability, and ease of maintenance
Optimization
Increased efficiency
Proven technology
Improved capabilities
Precision positioning
Tighter tolerances
As Lincoln Park Boring expanded into new types of work, including large parts, it needed to upgrade its legacy equipment. The company decided to invest in a new boring-mill machine from Fives Giddings & Lewis to handle new production capabilities and meet its customers’ changing demands.
The machine required robust controls to deliver the performance needed for the type of work Lincoln Park Boring performs. This led Fives, a FANUC-authorized integrator, to install a FANUC 0iF CNC.
Lincoln Park Boring wanted a control that had the flexibility to be used manually and could enable quick setups for low-part runs. Fives partnered with FANUC to customize the control’s human-machine interface with a subplate that has a separate joystick and includes the speeds and feeds. This allows operators to use the machine manually, so they don’t have to program the control to produce one or two parts.
The result is a machine that has more capabilities and can hold tighter tolerances than many of its other equipment. Additionally, the control is able to run the equipment faster to accommodate rapid travel rates.
Since the new FIVES machine tool, Lincoln Park has decided to retrofit one of their legacy machine tools with new FANUC controls.
Rick yesue lincoln park boring co
We’ve had very good luck with FANUC. We don’t have a lot of service calls. It’s the kind of thing where, when it’s not happening, you almost don’t notice it, but when you look back and you’ve had problems with other things, that’s when you notice it. Anything we retrofit would have a FANUC control.
Rick Yesue President – Lincoln Park Boring Company
FANUC CNC Controls 0i MF Plus
0i-MF Plus
FANUC 0i-MF Plus CNC delivers efficient, high-quality milling with reduced cycle times, smooth surface finishes, customizable functions, and flexible HMI.
View 0i-MF Plus
Fives logo white3
Fives Group
To bring its equipment up to 21st-century standards, Lincoln Park enlisted the help of machine builder Fives Giddings & Lewis, a FANUC-authorized integrator. By installing FANUC controls in the retrofit, Lincoln Park now has a machine with much more capabilities and tighter tolerances than before.
Visit Website https://www.fivesgroup.com/
For more than 60 years, this family-owned and operated business has handled the production of large parts and metal fabrication across different industries. The Lincoln Park Boring Company largely specializes in manufacturing parts of larger machines used to produce components for woodworking, machine tool cutting, grinding, and more.
Visit Website
