  5. FANUC America Demonstrates Robotic and CNC Education Cells at ACTE’s Career Tech Vision 2015
FANUC showcases robotic and CNC education solutions at ACTE 2015, supporting STEM learning with hands-on automation and training tools.
4 min
ROCHESTER HILLS, Mich., Nov. 20, 2015 – FANUC America Corporation will demonstrate robotic and CNC cells designed for the education market during ACTE’s Career Tech Vision 2015, Nov. 20-21, held at the Ernest Morial Convention Center, New Orleans, booth #916.
“Our education programs are aligned with STEM initiatives to support technical education and career paths,” said Paul Aiello, director, FANUC Certified Education Training (CERT).  “We collaborate with industry and education to encourage the development of innovative curriculums based on today’s industry needs.  Companies committed to working with CERT training programs are then able to hire locally trained students that have advanced automation skills.”
FANUC will feature the following education demonstrations:
FANUC CNC Simulator
The FANUC CNC simulator is the perfect addition to the classroom and provides maximum exposure to FANUC CNC controls when actual machine time is limited. Based on the FANUC 0iF platform, the simulator allows you to switch between milling and turning configurations at power on to teach programming, navigation and operation on the world’s most popular CNC control.
Simple configurations make it easy to learn how to operate and edit data on a modern FANUC control. FANUC’s MGi conversational interface allows users to graphically generate programs that are simulated in 3D, and then convert the programs back to conventional NC programs for use on machine tools using FANUC controls. Students use Flash ATA and USB interfaces to upload and download (read and punch), and DNC functions are supported by Ethernet and Flash ATA card.
Dual Check Safety (DCS) Fenceless CERT Cart
At the show, attendees will be able to safely approach and interact with a FANUC LR Mate 200iD/4S robot in the DCS Fenceless Zones CERT Cart demonstration. The LR Mate 200iD/4S operates with no safety fences surrounding it. Instead, it uses DCS and a series of area scanners to safely monitor robot motion area and speed, and any intrusions into each zone surrounding the robot.
Ergonomic features of this highly portable education unit include a fold up tabletop that is easy to expand and collapse, locking caster wheels, and easy power on with a simple wall outlet plug. The open tabletop design of the DCS Fenceless Zones CERT Cart offers the robot over 180 degrees of movement. This wide robot motion range offers greater programming flexibility and operation. Additionally, the robot’s end-of-arm tool comes with many options, further adding to the product’s flexibility.
In the DCS Fenceless Zones CERT Cart, the robot moves at normal speed when no operator is in the monitored zones. If an operator approaches the “slow down zone,” area sensors detect the intrusion and the robot slows down. If the operator enters the robot motion area or “stop zone,” the robot comes to a complete stop. An integrated safety stack light indicates zone activity.
“The area sensors surrounding the platform create a virtual wall around the robot, allowing an operator to load or unload parts to the part tray,” said Aiello. “This allows for convenience of easy part changeover and interaction between the instructor or student and the robot without the need for safety fences.”
Levil WL-F-400B Mill
The Levil WL-F-400B Mill is a portable, compact industrial machine designed for use in the classroom to familiarize students with milling practices, including machine programming, setup and operation.
The mill uses the world-renowned FANUC 0i-Mate MODEL D control, runs on a standard single-phase 110vAC outlet, and can be moved from class to class through standard doorways.
“The FANUC CNC mill offers a small footprint allowing it to easily fit into student labs,” said Dean Steadman, manager, CNC education development, FANUC America.  “For those new to milling operations, hands-on learning on our smaller equipment is much less intimidating than the larger machines.”
At the show the Levil milling machine will produce an aluminum business card holder with engraving, highlighting its three-axis milling capabilities.
