  5. FANUC CNC and Robotics Integration Simplifies Operations
The new feature enables FANUC CNCs to directly program robots through the G-code.
2 min
HOFFMAN ESTATES, IL – FANUC America, a leading factory automation solutions provider, introduces the next step in complete robotics and CNCs integration for more efficient operations. FANUC CNCs now have the ability to control connected FANUC robots providing machine tending or other assistance through FANUC’s Robot and CNC Integration.
More manufacturing operations are taking advantage of adding more robotics to execute repetitive tasks previously manually performed. Advanced automation offers a competitive edge and greater profit margins to shops of all sizes.
FANUC’s Robot and CNC Integration is a complete package that simplifies the connection of a FANUC robot to a FANUC controlled machine tool. The new Robot G-code feature allows operators and machine tool builders to program robots easily through the FANUC CNC in ISO standard G-code format. Those unfamiliar with robotic programming language will no longer require additional training or specialists because the programming can be performed with G-codes. A reliance on a separate teach pendant for the robot is also greatly reduced with the capability of robotic programming and operation through the CNC user interface.
FANUC’s Robot and CNC Integration not only makes connecting a FANUC robot through a high-speed Ethernet cable to a machine tool easy, but also simplifies the setup, programming and operation. The Robot G-code feature is available on FANUC CNC Series 0i-F, 0i-F Plus, 30i-B and 30i-B Plus.
