  5. Scaling Capacity for Data Center Demand with Automated Coil Coating
See how Modexus Solutions automated coil coating for data center demand, increasing capacity while reducing material use.
Solution By
Thierica Equipment
Thierica Equipment
P 250 Coating
https://www.fanucamerica.com/case-studies/scaling-capacity-for-data-center-demand-with-automated-coil-coating
Increasing production capacity to meet growing demand
Labor-intensive manual coating process
Maintaining coating quality and consistency
04
Controlling production waste and material costs
Statistics graph line
Faster production cycles and higher throughput through an integrated automated process
Safety protection shield
Improved worker safety and workforce optimization
More consistent coating application and quality control
Sustainability
Sustainable material consumption with less waste
P 250 Coating
As demand for data center cooling systems continued to rise, Modexus Solutions reevaluated a process that had long relied on manual labor. What had once seemed like a distant automation opportunity became a practical solution to the company's growing production capacity needs. With the introduction of FANUC robotics at its Jacksonville, Texas facility, Modexus increased throughput while maintaining the quality standards customers depend on to protect critical heat transfer equipment from corrosion and decay.
Modexus’ Jacksonville location focuses on applying protective coatings to coils used in commercial HVAC, industrial cooling and data center applications. These coatings help extend and preserve product life. Until this year, the facility's top coat application process was performed with two to three operators spraying large coils inside dedicated coating booths. While effective, the process required skilled labor, exposed employees to a demanding work environment and limited the facility's ability to scale production efficiently.
To support the next phase of its manufacturing growth, Modexus partnered with Thierica Automation & Equipment, a machine building company with decades of experience designing custom automated coating and finishing systems. Working closely with the Modexus team, Thierica evaluated multiple layouts, process configurations and equipment designs to develop a solution that would fit within the facility's available floor space while supporting increased production volumes.
Before installation, the company conducted extensive lab testing and validation using Modexus’ actual coil samples. This confirmed that the robotic application could achieve a more efficient coating penetration and necessary coverage across the product's deep fin structure. The FANUC P-250iB paint robots were selected for their ability to operate within the facility's space constraints, as well as their reach. The robots deliver consistent coating coverage across large and complex coil assemblies while reducing the need for manual spraying. Thierica also leveraged FANUC simulation software to optimize robot paths, reduce cycle times and verify system performance before equipment was ever installed on the production floor.
The resulting solution transformed the top coat application into a highly automated workflow. The process starts with the electrocoated coils being loaded on the overhead conveyer, where they begin moving down the line, entering a high heat oven that cures the e-coat application. The coils cool while moving to the robotic coating application, where the front and backside of the coils automatically receive a protective coating spray by two FANUC P-250 robots in separate booths. The coils then move through another oven, curing the top coat with a low heat bake, before finishing their cycle by cooling and being unloaded by Modexus employees.
Beyond increasing capacity, the automated system improves several key aspects of the operation. What was once a labor-intensive process has effectively become a load-and-unload operation supported by robotic automation. Employees are no longer required to perform repetitive coating tasks inside the spray environment, reducing ergonomic and workplace exposure concerns. The automated application further improves coating consistency, minimizes material consumption and maintains compliance with quality requirements.
For Modexus, the benefits extend beyond a single production line. The Jacksonville installation serves as a blueprint for how automation can support future growth across the company's coatings operations. As demand for cooling infrastructure continues to rise, the success of the project with Thierica Automation & Equipment demonstrates how robotics and advanced process automation can help manufacturers scale production, improve quality and create safer working environments without compromising performance.
Looking ahead, Modexus sees opportunities to apply similar technologies at additional facilities around the world. What began as an effort to increase capacity has become a model for future automation investments, helping the company meet growing customer demand while improving efficiency, consistency and operational performance.
Terry De Rise
Automation changes our plan. We’re focused on safety, we're focused on the environment, and we're really looking forward to the efficiency and throughput opportunities that this is going to give us.
Terry DeRise Plant Manager – Modexus Solutions
P-250iB
Paint
P-250iB
FANUC P‑250iB paint robot is the industry’s best solution for large and mid-size painting jobs, suitable for a wide range of painting and coating applications.
15 kg
2800 mm
View P-250iB
Thierica Equipment
Thierica Equipment
Founded in 1945, Thierica Automation & Equipment is known for developing custom automation and finishing solutions that help manufacturers improve productivity, quality and operational performance. Serving customers across a variety of industries, the company designs, manufactures, installs and services integrated systems for coating, assembly and material handling applications. Through its in-house engineering and manufacturing expertise, Thierica delivers turnkey solutions tailored to each customer's unique production requirements.
Visit Website http://www.thiequip.com
MS Logo Blue and Navy no Tagline or TM
Modexus Solutions
Modexus Solutions is a global leader in thermal management technology, providing heating, cooling and ventilation solutions for commercial, industrial and mission-critical applications for more than 100 years. With operations across North America, Europe and Asia, the company serves a wide range of markets, including HVAC, data centers, automotive, industrial manufacturing and energy. The company delivers specialized corrosion-resistant coating solutions that help extend the life and performance of heat transfer equipment operating in demanding environments.
Visit Website
