Robotunits
Cobot Device
Cobot-Station
By Robotunits Pedestals, Carts
Applications such as machine operation, assembly, gluing applications or simple pick & place tasks can be quickly handled. There is sufficient space in the substructure to accomodate the most common Cobot controllers. These are also easily accessible via the door. Application-specific components (such as holders for teach pendants, workpiece holders, tools, etc.) can be mounted to the open t-slots of the work surface. Push buttons or sensors can be subsequently mounted by the operator. Via lifting rollers with integrated locking feet, the substructure is mobile and can be stably positioned for operation.
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
Compatible Controllers
Machine Tending
CRX 10i A Paint Inspection
Inspection
