MurrPlastik Systems, Inc.
Cobot Device
Flexible Holder System for FANUC CRX
By MurrPlastik Systems, Inc. Other
Sets specially designed for cable routing on FANUC CRX 10i robots. This flexible holder system, built to simplify cobot cable management, includes the protective conduit, end sleeves, and the appropriate fastening with a non-slip hook and loop tape. For an easier installation of pre-assembled cables, the protective conduit is available in slotted LS. The set offers the lowest possible interference contour for a low risk of damage.
Device Features
  • Specially designed for cable routing on CRX robots
  • Mounting and fastening is easy with a non-slip hook and loop tape
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
Compatible Controllers
Machine Tending
CRX 10i A Paint Inspection
Inspection
