  5. FANUC Demonstrates New P-350iA/45 Painting and Coating Robot at IMTS 2016.
FANUC showcases the P-350iA/45 robot at IMTS 2016, delivering precise sanding, coating, and washing with high payload and flexible automation.
2 min
ROCHESTER HILLS, MI – (Sept. 12, 2016) FANUC America Corporation will demonstrate sanding, washing and drying an aircraft fuselage with the new P-350iA/45 painting and coating robot at IMTS 2016, booth #S-8919.
The new P-350iA/45 robot equipped with a sanding tool will simulate sanding an aircraft fuselage.  At the start of the cycle, the robot will automatically change the sandpaper pad. Upon completion of sanding, the robot connects to a washing applicator and simulates a wash routine. It will then make a second pass to dry the fuselage with compressed air.  A projected image will show the application. The cell will highlight the robot’s flexibility, payload, reach and precision.
Intelligent P-350iA/45 Paint Robot
The new FANUC P-350iA/45 intelligent robot is the latest in a series of painting robots offered by FANUC since 1982.  Designed for a variety of applications including painting, coating, sanding, and washing, it offers a flexible six-axis design and is Class 1, Division 1 approved for operation in hazardous environments.  A 45 kg payload makes it the strongest paint robot in its classification.  Based on FANUC’s M-710iC robot series, the P-350iA/45 offers the same reliability and proven technology of all FANUC products.
Intelligent P-350iA/45 Paint Robot Features and Benefits
  • 360-degree rotation of J1 enables multi-direction operation.
  • Durable cast aluminum outer arm withstands harsh conditions.
  • 45 kg payload makes it the strongest robot in the C1/D1 classification.
  • Slim arm with a 2606 mm reach allows operation in tight work spaces.
  • High-speed operation minimizes robot cycle times.
  • Purged and pressurized arm is FM and ATEX Class Div. 1 approved which maximizes reliability with FANUC’s standard purge module.
  • IP67 rated wrist allows operation in wet conditions.
  • Supports FANUC’s latest intelligent software tool packages including PaintTool, HandlingTool and SpotTool.
