  5. FANUC Demonstrates New R-2000iC/210WE Washer Robot at IMTS 2016
FANUC showcases the R-2000iC washer robot at IMTS 2016, delivering high-pressure cleaning, durability, and efficient automation for industrial wash applications.
3 min
ROCHESTER HILLS, MI – (Sept. 12, 2016) FANUC America Corporation will demonstrate a wash and clean-off process with the new R-2000iC/210WE washer robot and LR Mate 200iD/7WP mini-material handling robot at IMTS 2016, booth #S-8919.
The new R-2000iC/210WE will handle an engine block in a high-pressure washing demonstration. An LR Mate 200iD/7WP will perform a blow-off operation to specific areas of the block.
New Intelligent R-2000iC/210WE Robot
The new R-2000iC/210WE is part of FANUC’s popular R-2000iC family of industrial robots, including pedestal and rack mount versions with a variety of payloads and reaches.  Designed to withstand direct spray, the R-2000iC/210WE is ideal for the wash environment.  It features a durable coating with stainless steel covers to withstand high-pressure spray.  It is slim and compact, minimizing floor space requirements and offers a variety of enhancements that help simplify maintenance including a built-in pressure sensor and easy access to lubrication ports.
R-2000iC/210WE Features and Benefits
  • R-2000iC/210WE robot offers a heavy 210 kg payload and a long 2655 mm reach.
  • Fast and accurate with FANUC’s world-renowned motion control technology.
  • Air purged covers and castings to prevent water accumulation.
  • IP69 rated connection cables allows operation in wet conditions.
  • Ideal for high-pressure washer systems.
  • Supports a wide range of intelligent functions including iRVision and Force Sensing.
FANUC LR Mate 200iD Robots
The family of LR Mate 200iD robots is a versatile solution for a wide range of manufacturing operations that require access into small spaces.  A very slim arm about the same size as a human arm, and a bottom cable exit option minimize interference with peripheral devices.  The LR Mate 200iD robots offer a “best in class” work envelope for both upright and invert mount installations. The LR Mate 200iD robots are also available with ISO Class 4 clean-room and food-grade variants for food handling and healthcare packaging applications.
