Servo Learning Oscillation
Servo Learning Oscillation uses controlled tool oscillation to break chips, improve disposal, reduce downtime, and enable continuous, efficient machining.
FANUC’s Servo Learning Oscillation
Automatically shreds chips for easier and safer chip disposal
Material removed during turning or milling/drilling applications from a workpiece can result in long, stringy chips that can become entangled. Here’s a video that shows what cutting looks like without Servo Learning Oscillation:
Servo Learning Oscillation Off
Long, stringy chips form during cutting without Servo Learning Oscillation, causing tangles, poor part quality, added equipment costs, and potential downtime.
Buying equipment for crushing and conveying these chips can add extra cost and complications to the machining process. Worse yet, not effectively managing chip disposal can cause machine failure and degraded part quality, which all adds to production downtime and delays.
Cnc oscillation tangled
FANUC’s Servo Learning Oscillation shreds chips by oscillation cutting
Servo Learning Oscillation Video Oscillation ON
Servo Learning Oscillation automatically oscillates the tool to shred chips, improve cut quality, reduce maintenance, and prevent downtime.
Benefits of Servo Learning Oscillation
  • Improved chip disposal protects staff from sharp strings and allows them to focus on higher-value work
  • Chips are automatically shredded for continuous, high-volume production
  • Improved chip disposal helps free up maintenance staff
  • Cleaner cutting produces better quality parts
  • Shredded chips help protect the machine from unexpected downtime
  • No extra equipment needed for chip disposal
  • Easy to set via customized G-code
