Find Common Errors
Quickly identify errors that people commonly make. Corrective and improvement actions can be planned to prevent future issues
Maximize Your Uptime
FANUC’s Zero Down Time application (ZDT) is a solution to reduce down time and enhance overall robot performance using predictive analytics. It can be used to Improve productivity, optimize maintenance and increase the life of your FANUC robots.
Zero Down Time (ZDT) continuously monitors robot condition and performance data to identify potential issues before they impact production. By analyzing system behavior and trends, it helps maintenance teams take proactive action rather than reacting to failures. This supports improved uptime, reduced unplanned downtime, and more predictable operations in high-volume manufacturing and critical automation environments.
FANUC ZDT (Zero Downtime) is an advanced predictive maintenance solution that monitors robot performance in real time to prevent unexpected failures. It detects issues before they impact production, ensuring maximum efficiency and uptime. Stay ahead with proactive maintenance and optimize your automation operations.
Improve operating time by analyzing history to identify hidden problems
Looks for abnormalities in mechanical health, such as reducers, or servo motors and alerts before failure to schedule maintenance.
With a global network, FANUC support is available to meet your needs quickly and effectively.
Improve robot uptime and internal processes based on operational status monitoring resulting in maximized production.
View information from anywhere via a secure web portal account.
ZDT continuously collects and analyzes data to track each robot’s overall health and maintenance requirements while running production. ZDT will notify you if action is required to prevent unexpected downtime so you are free to focus on other responsibilities.
Access information about your ZDT protected robots from anywhere in the world. You can see robot details at each of your locations, view analytic results, check robot health, maintenance status, and more.
Allows the robot to leverage the HTTPS client to send encrypted messages to the ZDT Data Collector.
