- Max Payload:
- 10 kg
- Reach:
- 1418 mm
Grit W is an out of the box solution for sanding any size wood or MDF cabinet doors or drawer fronts. Uses a vision system to acquire door dimensions. Easy to use vacuum work holding fixture adjusts to fit any size cabinet door.
