  5. Excalibur Tool Makes Reliable CNC Machines with FANUC Technology
Excalibur Tools boosted customer output by 300% with a FANUC robot-integrated grinding system that delivers precision, efficiency, and repeatability.
Solution By
Excalibur logo
Excalibur Tool Inc.
Last Updated July 21, 2026
Excalibur case study cover
https://www.fanucamerica.com/case-studies/excalibur-tool
Build a 6-axis grinding machine for double-ended tools
Acquire precision, efficiency, and flexibility in an automation solution
Select reliable, durable products that are easy to use
Third party machine
A Top-of-the-Line Tool Grinding Machine
Call center
Lifetime Support Network
Machine uptime
Worry-Free Operation with Foolproof Products
Excalibur Tools was tasked with developing and building a machine for a client that could efficiently and precisely produce double-ended tools like Allen wrenches. Incorporating a FANUC robot into this machine and including a part flipper allowed Excalibur to create a repeatable process that could efficiently grind both ends of a tool.
Equipped with a FANUC Series 30i-B CNC and integrated with a FANUC LR Mate 200iD robot for machining tending, the ERG-6 RoboGrind processes the parts only once, which has increased production for the client by 300%.
Additionally, communications between the robot and CNC have been simplified by using FANUC I/O Link i. This system enables the robot to automatically adjust lengths or cycle times when a different part program is entered into the CNC, eliminating extra programming as well as minimizing miscommunication.
Daniel wayman excalibur tool
FANUC has lifetime support on all their parts. I don’t have to worry about the FANUC end of things or the support end of things because I have them behind me.
Daniel Wayman President – Excalibur Tool Inc.
LR Mate 200iD
Articulated Robots
LR Mate 200iD
7 kg
717 mm
View LR Mate 200iD
30i model B Plus i H 10 Data
30i-B Plus
FANUC 30i-B Plus CNC delivers high-speed, ultra-precise multi-axis machining with multipath control and proven reliability for demanding applications.
View 30i-B Plus
Excalibur logo
Excalibur Tool Inc.
Excalibur Tool Inc. provides value-priced CNC tool grinders for end mills, drills, routers, and burrs to the tool grinding industry. For more than 10 years, Excalibur has been innovating tool grinding machines to help tool manufacturers produce their products more efficiently and consistently.
