GRIP GmbH
Cobot Device
Auto Connector AC063
By GRIP GmbH Other
The Auto Connector is a new type of mechanical connection system that enables fully automatic tool changes. The Auto Connector system is composed of an upper assembly and a lower assembly. The upper assembly houses the locking mechanism, which ensures a precise and form-locking fitment between the upper and lower assembly. The locking and unlocking mechanism is activated through the robot's own movement. Trays make it possible to park multiple types of end of arm tools. An external energy source is not required for the Auto Connector to perform its automatic tool change.
Device Features
  • Fully automatic end of arm tool change
  • Interface according to DIN EN ISO 9409-1
  • High repeatability < 0.02 mm
  • Durable – withstands over 1,000.000 changing cycles
  • Withstands high loads with low dead weight
  • The robot’s own movement activates the locking and unlocking mechanism
  • No external energy such as compressed air or electric are required
  • Integrated pneumatic feedthroughs
  • Module for electric actuated tools is optional
  • Machined out of high strength aluminum and anodized
  • A spring actuated pin ensures additional safety during operation
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
Machine Tending
CRX Handling Metal Block 1
Material Handling
