IME Automation
Cobot Device
Skippy The Mobile Robot Cart
By IME Automation Pedestals, Carts
Drop-In FANUC CRX Compatibility: Designed with dedicated mechanical mounting footprints, interior space, and ventilation for standard FANUC CRX controllers. Accommodates the factory-provided FANUC teach pendant cradle directly onto the cart structure.
Mechanical Docking Repeatability: IME’s proprietary docking stations and 4,000 lb toggle clamp ensure the cart is rigidly anchored in the exact same location every time. This repeatability eliminates the need for your software engineers to program complex vision alignment, touch up robot points, or recalibrate coordinates when the cart is moved.
  • X-Axis (Lateral): +/-0.035 in (+/-0.9 mm)
  • Y-Axis (Fore/Aft): +/-0.075 in (+/-1.9 mm)
Hardware-Based Safety Interlocks: Skippy features a robust mechanical and electronic safety-interlock system. The cart physically and electronically prevents the robot from operating unless it is perfectly locked into its docking plate—providing a turnkey, Category 3 PLe-compliant foundation that ties directly into the FANUC Dual Check Safety (DCS) system.
Smart Station Recognition: Skip the custom PLC code for station identification. The moment the cart docks, a built-in RFID coupling system identifies the specific station and provides a clean, easily mapped I/O handshake to the FANUC controller, triggering the correct operational mode or recipe.
All-in-One Utility Routing: Reduce clutter with built-in, auto-retracting utility reels (power/air), an integrated air regulator, and a water condensation collector already built into the chassis.
Industrial Mobility Infrastructure: Built for the realities of a factory floor, featuring integrated dual-sided forklift slots for long-distance transport and smooth-rolling polyurethane wheels for quick, effortless localized positioning by a single operator.
Device Features
How It Works:
ROLL: The operator rolls the Skippy platform (housing your integrated FANUC CRX and pallet program) to a production line and engages the Zero-Point Docking System. The mechanical Dock locks the cart at a precisely fixed point.
DOCK: The operator connects the retractable power and air lines to facility drops. Skippy’s integrated RFID sensors instantly recognize the station and output a signal to the FANUC controller to automatically pull up the correct product recipe or program for that specific line.
RUN: The operator confirms the auto-loaded recipe on the FANUC teach pendant and presses start. The cobot begins working immediately with flawless spatial alignment.
Width
36"
Depth
32"
Height (without robot)
26 3/4"
CRX-10iA
1249 mm
View CRX-10iA
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
View CRX-10iA/L
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
CRX 10i A Paint Inspection
Inspection
Machine Tending
CRX Handling Metal Block 1
Material Handling
