R-50iA
Precision wire feed control
Servo Torch is a fully-integrated, servo-controlled, wrist-mounted, four-roll (4) “Pull” wire feeder controlled by the ARC Mate® series robots. The design is optimized to feed aluminum and soft wire. Integration of the wire feed motor with the motion control of the robot results in a close coupling of the welding process.
