Mission Buddy System for Dispensing
Buddy systen dispense
Cut out with pick to light 2
Robot & Go Solution
Dispense Buddy
The Dispense Buddy from Mission Design & Automation is part of the innovative Buddy System, designed to streamline repetitive manufacturing tasks. This collaborative robot application features a user-friendly path planning interface and end-of-arm-tool that requires no prior robotics experience, making it accessible for operators to program and use. The Dispense Buddy is versatile, capable of handling various dispensing applications with precision and consistency, with end of arm dispense tools designed to handle single component and two-component materials. Its lightweight and mobile design allows it to be easily redeployed across different tasks without altering production layouts. Additionally, the robot's safety features enable safe human-robot collaboration, enhancing productivity and efficiency on the shop floor. Drag-and-drop path planning allow users to easily develop and modify dispense paths, whether it’s a single dispense path or a repeated array onto a tray of parts. Paths can be stored and reused as needed for your high-mix, low-volume production runs.
Power
120 VAC, 10A
Dispense Types
1-component or 2-component precision dispense
End of Arm Tooling Types
Custom interchangeable 1-component or 2-component dispensers built to achieve your specific dispense goals. We partner with leading dispense equipment manufacturers for tooling integration, including GP Reeves 1K Progressive Screw Precision Dispenser, Nordson EFD UltimusPlus 1-11 1K Syringe Dispenser, 1K preeflow® eco-PEN450, and have in-house capability to design new or integrate existing dispensers.
Safety Features
Optional area scanner, optional light curtains, optional hard guarding
Additional Features
Air compressor, custom nesting, multiple work stations/fixture plates, ergonomic height-adjustable table
Additional Tooling Options
Pick-to-light bins, 3M Adhesive Mix Monitor System, Custom Curing Equipment, and more.
Size Range
994mm reach (CRX-5iA) through 1756mm reach (CRX-30iA)
View CRX-10iA/L
CRX-5iA Food Grade
CRX-5iA Food Grade
The FANUC CRX-5iA Food-Grade Cobot ensures safe automation in food & beverage with a 5kg payload, 994mm reach, and user-friendly programming.
5 kg
994 mm
View CRX-5iA Food Grade
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-5iA Cobot
CRX-5iA
Improve efficiency with the FANUC CRX-5iA cobot. Its 5kg payload, 994mm reach, and intuitive programming make it ideal for manufacturers.
5 kg
994 mm
View CRX-5iA
