Smart Load 1500 FANUC Cobot Go Thumbnail
Smart Load 1500 FANUC Cobot Go Render 1
Smart Load 1500 FANUC Cobot Go Render 2
Smart Load 1500 FANUC Cobot Go Render 3
Smart Load 1500 FANUC Cobot Go Render 4
Smart Load 1500 FANUC Cobot Go 1
Smart Load 1500 FANUC Cobot Go 2
Smart Load 1500 FANUC Cobot Go 3
IC Automation
Robot & Go Solution
SmartLoad 1500
The SmartLoad Machine Tending System is engineered to maximize machine productivity while keeping setup incredibly simple. Designed as a compact, mobile automation platform, SmartLoad helps manufacturers increase spindle uptime, reduce manual handling, and achieve consistent output without the complexity typically associated with robotic integration.
SmartLoad combines a robotic arm, intuitive HMI, and a small-footprint base to load and unload parts directly into existing CNC machines. Operators place raw parts into the locating drawers, select the job on the touchscreen, and SmartLoad manages the entire tending process with speed, accuracy, and repeatability. Preprogrammed routines allow for fast setup and effortless changeovers—switching from one part to another requires only a few taps and minimal adjustments.
With built-in safety features and true mobility, SmartLoad can be moved between machines as production needs change, maximizing utilization and reducing downtime. The result is a practical, cost-effective automation solution that delivers immediate productivity gains while freeing your team to focus on higher-value work.
Solution Features
  • Compact & Mobile Design
  • Seamless Integration
  • User-Friendly HMI
  • Built-In Safety Features
  • Quick Setup & Redeployment
  • Proven Productivity Gains
Standard extension cord socket available for quick connect power
Power
120V / 20A
Air
Standard 3/8 airline with 1/4” industrial quick disconnect fitting
View CRX-10iA/L
