Contents
- 1. Add Automation:
- 2. Use the Latest and Greatest Machining Practices and Technology:
- 3. Digitize the Machining Process:
- 4. Upgrade with a CNC Retrofit:
- 5. Refresh the CNC Interface:
- 6. Take Advantage of IoT:
- 7. Prepare for 5-axis Machining:
- 8. Training the Future Workforce:
- 9. Invest in Tested Motors:
- 10. Form Relationships with Trusted Partners:
A portion of this article first appeared in the March 2025 issue of Canadian Metalworking.
With the new advances in CNC technology, now is a great time for machine shops to critically take a look at processes and see areas for improvement. Many operations overlook evaluating their CNC equipment and how it can contribute to overall equipment effectiveness. Below are ten key steps manufacturers can take to boost their efficiency.
1. Add Automation:
Automation can increase production and efficiency no matter the type or complexity of the manufactured products. Even though many different industries are seeing the benefits of adding automation to their operations, smaller machine shops have been reluctant to make an initial investment in robotics. However, with the growing availability and affordability of flexible collaborative robotics, or cobots, more operations are becoming interested in this type of automation, especially for high-mix, low-volume applications. Labor and sometimes space can be at a premium in many smaller facilities, so machine shops should look for machine tending robots or cobots that are reliable, easy to integrate and have a smaller footprint. Adding cobots, robots and software that have the ability to be easily connected can improve throughput as well as overall equipment effectiveness.
Many manufacturers leave performance on the table due to outdated processes and programming. Are you getting the most out of your machining? Now’s the time to look at the advantages in new CNC technology. Because new controls have greater processing speeds and can implement advanced algorithms, they can do a lot more for your operations.
New digital tools are breathing innovation and life into increasingly more areas of manufacturing, including the application of digital twins in the machining industry. Digital twins provide virtualization of the machine, control and manufacturing process. Digitalizing traditional manufacturing processes have the potential to make operations more efficient by proving out production processes in the virtual world. That means less waste, more efficiency and a more equipped workforce.
Do you have legacy equipment? Running older CNC machines can have hidden costs, such as taking the time to source and find older replacement parts leading to significantly longer total downtime and production losses. However, scrapping old equipment and starting new might be too expensive, especially when factoring in tooling, fixturing, rigging and foundation costs. Plus, new machines may require more training for staff. A CNC retrofit, which replaces older CNC systems with new controls, industrial PCs, servos and cables, can speed up processing and reduce cycle time by as much as 50 percent.
The latest CNC interfaces have become simpler and more intuitive, so they are easier to use than ever before. With graphical designs that provide a similar look and feel to a smartphone, new high-definition displays and touchscreens can clearly show specific workpiece areas. This provides full visibility and zoom-in/zoom-out capabilities during machining, which can help operators verify the machining program.
If shopfloors are not yet taking advantage of IoT information, they need to make that a priority. In today’s business climate, real-time operational floor insight to enable data-driven decisions is critical. Software solutions exist to suit every manufacturer, whether you operate dozens of multi-axis machines or run a small job shop. To get real insight into operational problems, IoT software is key to effectively monitoring, collecting and analyzing operational data. With this type of software, users can view a snapshot of their operations remotely. For maintenance departments, the performance of the CNC’s components can be easily monitored and many systems send real-time alerts if a component is reaching the end of its expected lifespan. To further assist maintenance tasks, alerts can be linked to operation manuals that list detailed repair instructions.
Investment in 5-axis machining is predicted to ramp up as more operations produce more complex parts used in high-tech industries, such as aerospace and medical device production. From the CNC perspective, machine tools that have powerful controls with advanced functions for optimal 5-axis toolpaths can significantly help shops get the most out of their 5-axis machining. While it’s possible to do the required 5-axis machining with legacy controls or functions, the workflow is significantly simplified with modern CNC functionality.
As 5-axis machine tools use increases, the demand for 5-axis operators will exponentially grow. Training new or existing workers in an effective and innovative way will be key to bridging this skills gap. To help solve this shortage, 5-axis training simulation software can allow users to learn how to setup and operate advanced 5-axis milling machines. Simulation training can offer an immersive environment to practice and understand advanced machining techniques. Since 5-axis machining involves more complex machine setups, simulation software enables users to experiment with and prove out the machine setup and/or part program before modifying the actual machine.
Having reliable and powerful motors are at the very heart of every manufacturing facility. To help determine a quality motor before purchasing, it is important to know how they have been tested and what environments and conditions they are designed to work under. Some manufacturers test their motors for resistance to: vibration, electrical interference, leaking while submerged, mist penetration, extreme temperatures and premature wear. Motor OEMs with high standards will reject designs that can’t hold up to an equivalent of 30 years of use in each of those tests. For motors to be successful in manufacturing, motors must undergo the most rigorous of testing to ensure they can standup to harsh environments and tough cleaning procedures. Making sure your motor manufacturer has put its designs under a certain amount of torture testing can make or break an investment.
Whether you are starting an IoT, automation, OEE or another business journey endeavor, be sure the solutions you pick are from a well-known and respected provider. Having a partner that will work with you for the long haul is one of the most important decisions you can make. No matter the technology offered, if a company can’t form a relationship that will last a number of years, or worst, not be in existence in the next year or two, then the project can be doomed to fail. Product cycles and development of new products can take a significant amount of time, so choosing a company with a solid reputation and global support and service is key.
