4D Technology, an Onto Innovation Subsidiary
Cobot Device
4D InSpec 3D Surface Snapshot Gauge
By 4D Technology, an Onto Innovation Subsidiary Sensors Includes CRX Plugin
The 4D InSpec surface gauge is a precision instrument for non-contact surface defect measurement. With micrometer-level resolution, portability, affordability and ease-of-use, 4D InSpec puts high-resolution 3D surface measurement where it’s needed: on the factory floor, in machine shops, and in field maintenance applications.
Automated 4D InSpec measurements enable a high-throughput, high-resolution defect and feature inspection solution.  An automated system can measure dozens to hundreds of edge break features, chamfers, and defects in minutes rather than days, vastly improving throughput and driving down inspection costs.
Device Features
The 4D InSpec surface gauge is the first handheld or automated, precision instrument for non-contact surface defect measurement. With micrometer-level resolution, portability, affordability and ease-of-use, 4D InSpec puts high resolution 3D surface measurement where it’s needed: on the factory floor, in machine shops, and in field service applications.
Integrate the 4D InSpec with a FANUC CRX robot easily with the 4D FANUC plugin for a fully automated 3D, optical inspection system to measure features such as chamfer, radius and edge break and defects such as pits, dings, scratches and corrosion.
Automated 3D surface measurement of defects and features:
  • Increase inspection throughput
  • Measure large components and complex geometries directly – no replication needed
  • 2um resolution
  • Easy to implement and operate
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
CRX-5iA Food Grade
CRX-5iA Food Grade
5 kg
994 mm
View CRX-5iA Food Grade
CRX-20iA/L
20 kg
View CRX-20iA/L
View CRX-10iA/L
CRX-10iA
1249 mm
View CRX-10iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
CRX 10i A Paint Inspection
Inspection
