CR-35iB
The CR-35iB cobot lifts up to 50kg with a compact footprint, advanced sensors, and easy programming — ideal for tight spaces and heavy-duty tasks.
- Max Payload:
- 50 kg
- Reach:
- 1643 mm
Apera AI transforms plant performance by empowering robots with human-caliber vision and advanced artificial intelligence. Powered by 4D Vision, robots achieve up to 10X faster vision and 99.9% reliability in recognizing objects and completing tasks.
Designed for the real-world plant floor, Apera AI's 4D Vision is powered by advanced AI, enabling robots to adapt to shifting bins, changing lighting conditions, worn grippers, and complex part geometry—unlocking performance in the most demanding industrial settings. Only Apera equips robots to perform tasks like bin picking, racking, de-racking, assembly, and machine tending with unmatched precision, speed, and reliability.
No structured lights, no lasers. Apera stereo 4D Vision works in all lighting conditions—bright, dark, outside, or variable—without any special equipment.
An AI neural network trains synthetic parts through a million cycles to achieve >99.9% reliability in recognizing (complex, shiny, clear) objects and performing tasks.
In as little as 0.3 seconds, Apera can identify an object to pick and provide path planning to the robot—allowing for up to 2,000 picks per hour.
Apera leverages high quality 12MP+ stereo cameras to deliver detailed depth maps without bulky laser projectors, enabling cost-effective and scalable multi-camera robotic cells.
SIMPLE—No Vision Expertise Required
No-code tools, AI-powered calibration, and real-time diagnostics streamline deployment. Build and simulate your robotic cell in the Apera Forge design studio in minutes. AI training delivers a complete vision program tuned for high performance within 24-48 hours, ready to deploy on your plant floor.
It’s time to end robot blindness. Apera AI’s award-winning 4D Vision system unlocks plant performance, enabling automotive OEMs, Tier 1 suppliers, and other industrial manufacturers to achieve unmatched levels of productivity, quality, and cost savings.
Enhance productivity with the dependable FANUC CRX-20iA/L, featuring a 20 kg payload, extended reach, and user-friendly programming.
Food-grade collaborative robot with a 30 kg payload, hygienic construction, and intuitive wrist controls for easy teaching and deployment.
The FANUC CRX‑5iA Food-Grade Cobot ensures safe automation in food & beverage with a 5kg payload, 994mm reach, and user-friendly programming.
FANUC palletizing robots and cobots offer fast, precise, and safe automation for stacking boxes, bags, pails, or drums — boosting efficiency and care.
