IGUS
Cobot Device
CRX Cable Routing
By IGUS Other
In order to guarantee a clean and above all safe routing of cables and hoses on the CRX robot, we offer the appropriate fastening options with the igus cobot clamps as well as extra protection with the robust triflex R energy chain.
Robotic cable management options include the open TRE chain, the closed TRC chain, or the light TRL chain. With the 3 versions, you can choose between sizes 30 and 40.
Device Features
  • Easy installation and repair
  • Easy to add/remove cables
  • Protects cables from damage, dust, rust, grease, etc.
  • Provides a sleek, clean appearance
  • Compatible with all CRX models
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
CRX 10i A Paint Inspection
Inspection
CRX Handling Metal Block 1
Material Handling
