Techreo
Cobot Device
CRX Reach Extender
By Techreo Grippers & Tools
Techreo's Reach Extender extends the reach of cobots up to 610mm (24”) using a patented composite design which provides lightweight, low deflection, and built-in vibration damping. Anytime you want to reach further, Techreo’s reach extender reaches out in lengths from 305mm (12”) up to 610mm (24”) using a fraction of the J5 moment. Simple jumpers enable plug-n-play connections: with electric and air lines protected by going thru the inside of the structure. Extend your cell’s reach, protect your CRX from damage.
Device Features
  • Our largest model - at 610mm (24") - consumes only 15% of the J5 moment for a 20iA/L.
  • Plug and Play: Our wrist flange bolts directly to an adapter plate which is configured to your cobot's wrist (often ISO 50). For utilities, simple jumpers are required at the wrist for both electrical and pneumatic - the lines are protected thru the interior of the structure and are available at the tooling end.
  • Versus aluminum, Techreo's composite tubing is 35% lighter, 20-40% less deflection, and up to 50x faster vibration damping.
Custom lengths up to 610mm also available
Lengths Availible
305mm (12”), 406mm (16"), 508mm (20"), 24" (610mm)
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-10iA
1249 mm
View CRX-10iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
CRX-20iA/L
20 kg
View CRX-20iA/L
View CRX-10iA/L
Compatible Controllers
Machine Tending
CRX 10i A Paint Inspection
Inspection
M 800i A 60 Laser Cutting copy
Laser Applications
CRX Handling Metal Block 1
Material Handling
Painting
