EVOTEC
Cobot Device
EVOTEC Protective Cover
By EVOTEC Other
EVOTEC Protective covers for FANUC CRX series robots are helpful in any environment in which the robotic arm is exposed to harmful factors such as (but not limited to): dust, radiant heat, welding spatter and hot particles, corrosive chemicals, abrasives, moisture and many other. The covers help maintain optimal working condition of the robot and prevent damage caused by the harmful factors. Covers dedicated to food industry and cleanroom also help keep the working environment clean and prevent contamination of the product.
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-5iA Food Grade
CRX-5iA Food Grade
5 kg
994 mm
View CRX-5iA Food Grade
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-10iA
1249 mm
View CRX-10iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
CRX-20iA/L
20 kg
View CRX-20iA/L
View CRX-10iA/L
Compatible Controllers
Machine Tending
CRX Handling Metal Block 1
Material Handling
