Asyril
Cobot Device
EYE+
By Asyril Grippers & Tools Includes CRX Plugin
Includes two configurations wizards:
  • Wizard for configuring the network between your robot and your EYE+
  • Wizard for performing the hand-eye calibration
Includes block functions for easy programming through the teaching editor
Efficient integration of EYE+ to control the part quantity and the position of the parts on the Asycube.
Includes classical control commands accessible in TP programs (KAREL instructions)
Available for all robot models with R-30iB PLUS controller compatible Tablet TP Software version V9.40 or higher
Options that must be installed on the robot controller:
  • User socket messaging (R648)
  • Tablet TP (S527)
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
CRX-5iA Food Grade
CRX-5iA Food Grade
5 kg
994 mm
View CRX-5iA Food Grade
CRX-20iA/L
20 kg
View CRX-20iA/L
View CRX-10iA/L
CRX-10iA
1249 mm
View CRX-10iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
