ESTIC CORPORATION
Cobot Device
Fastening Solutions
By ESTIC CORPORATION Grippers & Tools Includes CRX Plugin
ESTIC is a comprehensive assembly manufacturer offering screw tightening and press-fitting systems, along with a wide range of related applications and automation equipment.
The combination of the Handy2000Touch controller and the FANUC CRX robot enables simple and immediate screw tightening automation. Intuitive programming via a dedicated plugin and single LAN cable connection allows for easy communication and control, ensuring smooth system integration.
Device Features
  • High-precision screw tightening tool equipped with torque and angle sensors
  • Hand tool directly adaptable to robots
  • Wide lineup of robot-specific tools available
  • Connection via a single LAN cable*
*Emergency stop I/O requires separate connection
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
CRX-5iA Food Grade
CRX-5iA Food Grade
5 kg
994 mm
View CRX-5iA Food Grade
CRX-20iA/L
20 kg
View CRX-20iA/L
View CRX-10iA/L
CRX-10iA
1249 mm
View CRX-10iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
