Cobot Device
geCKo Materials Dry Adhesive (gMDA)
Grippers & Tools
geCKo Materials is a bio-inspired Dry Adhesive that is ultra-strong, reusable, leaves no residue, and requires no force to detach. This enables current solutions to revolutionize while being cost saving and energy efficient. This also opens up new applications in industrial automation, robotic gripping, space & defense and more.
Device Features
  • Eliminates costly maintenance and energy-consuming vacuum pumps, freeing up space
  • Grasps smooth or semi-smooth materials
  • Enhances robotic arm manipulation
  • Surface-safe and leaves no residue
  • Handles tacky surfaces without transferring residue
  • Easily integrated into existing processes, saving time and money
  • Requires no pinching force
  • Patented IP for both product and manufacturing processes
Requires no energy or force to attach/release in milliseconds
Usage
Reusable up to 120,000 times; no residue
Temperature Operating Range
115C to +350C
Hold Strength
~120kPa
Material
Food-Safe/ Medical Grade Silicone
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-10iA
1249 mm
View CRX-10iA
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
View CRX-10iA/L
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
CRX-5iA Food Grade
CRX-5iA Food Grade
5 kg
994 mm
View CRX-5iA Food Grade
Compatible Controllers
Machine Tending
CRX Handling Metal Block 1
Material Handling
