Industrial Magnetics
Cobot Device
RoboMag™ Quick Changer
By Industrial Magnetics Grippers & Tools
Maximize your production time with rapid, 3-second magnetic/vacuum tool changes at an unbeatable price, minimizing cycle times and boosting efficiency. IMI’s new RoboMag™ Quick Changer includes the famous Transporter® Low Profile, which helps it to outperform vacuum cup style and grip style end effectors as it integrates seamlessly with major collaborative robot manufacturers’ units.
Device Features
  • Integrates with Collaborative Robots
  • Automated tool changes in under 3 seconds
  • Low-cost option
  • Positively secures different end of arm tools for different applications
  • Fail-safe patented locking mechanism
  • Operates on 25-60 psi shop air
  • Increases productivity and efficiency by eliminating manual tool changes
  • Custom designs for unique tools and applications
  • 3D printed - perfect for low to moderate pay load capacities
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
Machine Tending
CRX Handling Metal Block 1
Material Handling
Painting
