Mid-Mountain Materials, Inc.
Cobot Device
THERMOPAK® Robot Covers and Protective Systems
By Mid-Mountain Materials, Inc. Other
Mid-Mountain Materials, Inc. Has You (and Your Robot) Covered
Designed to perform in the most demanding environments, our custom made protective covers do more than shield your robot, they safeguard every essential component that keeps your system running smoothly. From hoses and wires to tools, cords, optics, brackets, and mounts, we engineer full coverage solutions tailored to your needs.
Our covers are fabricated using ARMATEX® SBN 13 ROBOTEX, a high performance textile developed exclusively for robotic protection. Durable, heat-resistant, and built to withstand abrasive and extreme industrial conditions, ROBOTEX ensures long lasting reliability where it matters most. Whatever the challenge, Mid-Mountain Materials, Inc. delivers protection you can trust, because when your robot’s protected, your productivity is too.
Device Features
  • Reduces downtime for maintenance and failure
  • UV resistant and waterproof
  • Protects from pollutants in the manufacturing environment
  • Excellent resistance to a wide range of fluids and chemicals
  • Customizable with ducting ports for thermal management
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
CRX-5iA Food Grade
CRX-5iA Food Grade
5 kg
994 mm
View CRX-5iA Food Grade
CRX-20iA/L
20 kg
View CRX-20iA/L
View CRX-10iA/L
CRX-10iA
1249 mm
View CRX-10iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
