Thomson
Cobot Device
Thomson Movotrak™ Cobot Transfer Unit (CTU)
By Thomson Pedestals, Carts
The first ever collaborative 7th axis, the CTU features collision detection settings for groundbreaking programming and control benefits, while adding a horizontal operating range up to 10 m to significantly boost productivity and output.
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
CRX 10i A Paint Inspection
Inspection
M 800i A 60 Laser Cutting copy
Laser Applications
CRX Handling Metal Block 1
Material Handling
Painting
