Impaqt Robotics
Cobot Device
vaQgrip – Universal Plug & Play Vacuum Grippers
By Impaqt Robotics Grippers & Tools
Simplify vacuum gripping for end-of-line packaging, palletizing, and material handling with Impaqt Robotics.
vaQgrip by Impaqt Robotics is a family of plug-and-play vacuum grippers designed to make vacuum automation faster, cleaner, and easier to scale. Built around a lightweight architecture with internal vacuum routing, vaQgrip eliminates external tubing and fittings, reducing clutter and cutting installation time to just minutes.
Device Features
The vaQgrip series covers a broad range of vacuum handling needs, from modular gripper system to ready-to-deploy palletizing solutions. Instead of custom-engineered vacuum EOAT, integrators can choose standardized grippers or a modular platform that simplifies deployment and ensures consistent performance across projects.
All vaQgrip grippers follow the same design principles: internal vacuum routing, clean integration, safe operation, and reliable vacuum gripping. Typical applications include end-of-line packaging, palletizing, pick-and-place, and general material handling where fast setup and efficient payload utilization are required.
vaQgrip Click – Modular Vacuum Gripper System
vaQgrip Click is the modular member of the vaQgrip family, designed for applications that require flexibility. Its tool-free, twist-to-connect architecture allows gripper layouts to be built, modified, and expanded without custom fabrication, while internal vacuum routing eliminates external hoses. This makes vaQgrip Click suitable for multi-SKU production and applications with frequent layout changes.
vaQgrip VQ10 – Lightweight Vacuum Gripper, 10 kg Payload
The vaQgrip VQ10 is a plug-and-play vacuum gripper designed for palletizing and material handling. Weighing 1 kg and supporting payloads up to 10 kg, it offers an excellent weight-to-payload ratio for collaborative and industrial robot cells. An integrated horizontal offset extends reach in palletizing applications, while dual-channel vacuum and internal routing provide reliable operation in compact, repeatable setups.
vaQgrip VQ20 – Lightweight Design, High-Payload Performance
The vaQgrip VQ20 extends the series to higher payload applications, handling up to 20 kg with a gripper weight of approximately 1.2 kg. Dual-channel vacuum provides stable gripping for high-volume palletizing and multi-carton handling. With internal vacuum routing, plug-and-play installation, and a compact mechanical design, the VQ20 supports efficient deployment in demanding industrial environments.
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
CRX Handling Metal Block 1
Material Handling
