  5. Innovating Tomorrow: FANUC to Showcase Cutting-Edge Robotics and Automation Solutions at Automate 2025
Crx collaborative robot grouping with crx 10ia l paint 1 1
From collaborative robots to advanced vision technologies, FANUC showcases groundbreaking innovations designed to maximize efficiency and transform manufacturing processes.
5 min
ROCHESTER HILLS, MI – (April 28, 2025) – FANUC America, a global industrial automation leader, will showcase its latest industrial and collaborative robotic innovations at Automate 2025. The event, held in Detroit from May 12-15, will feature several all-new applications designed to enhance efficiency and unlock increased productivity.
"Today, more than ever, automation is the key to reaching production targets, boosting efficiency, and ensuring employee satisfaction," says Mike Cicco, president and CEO of FANUC America. "From start-ups to large-scale manufacturers, FANUC provides industry-leading, dependable, and cost-effective automation solutions that help companies overcome their greatest challenges."
At Automate, FANUC will showcase a broad selection of new and innovative technologies:
  • Collaborative Robots Boasting Payloads Up to 50 KG
    Featuring FANUC CRX and CR cobots
    FANUC’s full line of collaborative robots—or cobots—will be on display, featuring industry-leading payloads of up to 50 KG and impressive maximum reach at 1,889 mm. Within the diverse cobot selection, FANUC will showcase its CRX-10iA/L Paint Cobot specifically designed for use in painting, coating and dispensing.
  • Autonomous Mobile Robot Automotive Kitting
    Featuring FANUC CRX-10iA/L Cobot
    Mounted on a third-party autonomous mobile robot, FANUC’s CRX-10iA/L Cobot will demonstrate automotive kitting as it uses FANUC’s iRVision 3DV vision sensor to accurately pick individual components of a vehicle side-view mirror and deliver the kit to a human operator for assembly and installation onto a door, easing the labor process and eliminating the need for manually delivering parts or kits to the assembly line.
  • Dual Cobot Paint Application with Load and Unload
    Featuring FANUC CRX-10iA/L Paint Cobot and CRX-20iA/L Cobot
    In this demonstration, FANUC will use two cobots, visual identification and advanced line tracking to identify, load, paint and unload electric guitar bodies. Using a CRX-10iA/L Paint Cobot with FANUC 3DV camera and iRVision, the system will visually track and simulate painting of the guitar bodies. Meanwhile, a CRX-20iA/L Cobot will leverage a fixed FANUC 3DV iRVision sensor and iRPickTool software in showcasing its impressive reach and line tracking capability to load and unload guitar bodies from a conveyor to a rack.
  • Collaborative Mobile Dispense Cart
    FANUC’s Integral Servo Dispenser Software is paired with revolutionary adhesive metering equipment to deliver a mobile dispensing system featuring more precise application, better control, better repeatability, and intuitive programming. In this demonstration, a FANUC CRX-30iA cobot features end-of-arm adhesive metering, FANUC 3DV/400 vision camera and SpotTool+ software to offer a reliable, repeatable, and easily programmable dispense solution in a compact and flexible footprint.
  • Collaborative Arc Welding with Integrated 7th Axis Rail
    In a two-station cell, FANUC will demonstrate the flexibility and increased productivity allowed when its CRX-10iA/L Cobot is integrated with a 7th axis rail. Featuring a single-axis positioner on one side and a flexible fabricating table on the other, an operator can easily load one cell while welding occurs at the other thanks to an increased work envelope.
  • Flexible Robotic Wet Machining
    Featuring FANUC M-800/60-20B industrial robot
    In this wet machining demonstration, FANUC’s high-precision M-800/60-20B industrial robot will mill and drill aluminum stock using a variety of tools and accommodating various mounting positions. Built to withstand harsh elements like water and debris, this 6-axis model, known for its rigidity and accuracy, offers a larger work envelope compared to similarly priced CNC machines. Additionally, its adaptability makes it suitable for repurposing across various applications.
  • R-50iA Controller Technologies Display
    Unique demonstration highlights the advanced capabilities of FANUC’s new R-50iA controller, featuring two FANUC LR Mate industrial robots performing bin picking and palletizing.
    The compact LR Mate/7-7D robot with FANUC’s 3DV/400 vision camera bin picks jumbled boxes from a container onto a conveyor. This robot is running python code natively on its paired FANUC controller. The second robot, LR Mate/7-9 long arm unit with a 3DV/400 camera and PalletTool Turbo II software—identifies the size of the box on the conveyor and palletizes it onto the appropriate pallet. This controller showcases new cybersecurity protocols including MQTT TLS, the use of a LDAPS server for user access control along with Software PLC capability for cell control and HMI functionality. Additionally, our new Teach Pendant with lighter weight and enhanced performance is featured.
Additional demonstrations showcasing FANUC capabilities, including inspection, welding and others will be available, including one of FANUC’s Cobot-and-Go pre-engineered solutions. Informative and interactive displays detailing CNC systems, ROBOGUIDE and Zero Down Time (ZDT) software, will also be located within the booth.
FANUC America's new technologies will be on display at Booth #2623. Attendees will have the opportunity to see live demonstrations, interact with FANUC's robotics and speak to experts, as well as learn more about how these advanced solutions can benefit their operations.
In Booth #8919, FANUC’s student booth will feature a variety of classroom-friendly, educational robot demonstrations.
Attendees can learn more about FANUC and its innovations at a variety of live events featuring the company’s leaders and subject matter experts:
  • Cobot and Go: The Latest Trends and Tech Advancements Making Cobots More Accessible
    FANUC America Manager Jerry Perez
    Monday, May 12 at 1:30 p.m. ET
  • Advanced Vision Guided Robotics
    FANUC Engineering Manager David Bruce
    Wednesday, May 12 at 8 a.m. ET
  • Mastering the Complexities of Robotic Depalletizing
    FANUC America Engineer Stacey Harimoto
    Wednesday, May 14 at 10:15 a.m. ET
  • Panel: Equipping the Modern Workforce for Careers in Robotics, Automation and Smart Manufacturing
    FANUC America Executive Director, Education, Paul Aiello
    Wednesday, May 14 at 1 p.m. ET
  • The Final Frontier of Automation in a High-Volume Automotive Paint Shop: Robotic Paint Repair on a Moving Line
    FANUC America Senior Staff Engineer, Paint, Thomas VanderPlas
    Tuesday, May 13 at 10:15 a.m. ET
