Develop, LLC
Robot & Go Solution
Modular Robot System (MRS)
The Modular Robot System (MRS) is a plug-and-play automation cell powered by FANUC robotics. It installs fast, redeploys in minutes, and scales with your operation through modular add-ons. With multi-zone palletizing, custom tooling options, and real-time data dashboards, MRS goes beyond standard cobots to deliver flexibility, usability, and ROI in under six months.
Solution Features
Modular Robot System (MRS) Features
  • Throughput - Cases Per Minute (CPM) 6 single cases (Up to 13 with safety scanners)
  • Rapid Redeployment – Move and relaunch in minutes
  • Operator-Friendly HMI – Drag-and-drop job setup, no coding
  • Modular Expandability – Conveyors, printers, scanners, labelers
  • Multi-Zone Palletizing – Flexible layouts
  • Custom End-of-Arm Tooling – Tailored for you
  • Real-Time Data Dashboards – Web-based performance tracking anywhere
  • End of Arm Tooling Type(s) - Coval - CVGC or Custom to your application
Software
  • The MRS runs on a web-based HMI with a drag-and-drop interface for job setup. Operators can build or adjust pallet patterns in minutes without coding or robotics expertise. The system supports multi-zone palletizing, recipe storage for repeat jobs, and remote access dashboards for live production data and performance tracking.
System Size
66" X 47"
Pallet Size
Any 42” x 48” GMA, CHEP, PECO, iGPS
Max Pallet Height
72"
Power Requirements
120 VAC / 20 Amp / 60 Hz
Safety
Area Scanners as needed
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
Compatible Controllers
R 30i B Plus Controller for Paint Beauty Shot
R-30iB Plus Controller - Paint
High-performance R‑30iB Plus Paint Controller with purge unit, boosting productivity, speed, accuracy, and safety for paint robot automation.
View R-30iB Plus Controller - Paint
R-30iB Plus Mate Cabinet
View R-30iB Plus Mate Cabinet
R30i B Plus B Cab Beauty Shot
R-30iB Plus B-Cabinet
View R-30iB Plus B-Cabinet
R-30iB Plus A-Cabinet
View R-30iB Plus A-Cabinet
CRX Handling Metal Block 1
Material Handling
See It In Action
