3D.aero GmbH
Cobot Device
3D.EasyTeach
By 3D.aero GmbH Sensors
3D.EasyTeach is a no-code teaching solution for robotic paint applications. It allows skilled painters and operators to guide the process manually, while the system records the motion using infrared tracking technology and converts it into an optimized robot-ready paint program. Adjustments can be made directly in the software for fast refinement and repeatable results.
Device Features
  • Eliminates manual programming
  • Ensures consistent, high-quality coating
  • Fast and easy no-code teaching
  • Turns painter movement into robot programs
  • Works for small batches and changing parts
  • Teach new parts in under 10 minutes
Atex Markings: certification ongoing, markings may be subjected to changes
Max. field of view
3 m height: 2 x 2 m ground
Max. range
5 m
Tracking accuracy
+/- 1 mm
Max. speed in line tracking
10 m / min
Tool
II 3G Ex c IIB T5 Gc, II 3D Ex c IIIC T5 Dc
Power Requirements
110 V UL-normal Power Requirements
FANUC CRX-3iA cobot
CRX-3iA
Ultra-lightweight collaborative robot weighing 11 kg with 692 mm reach, designed for fast, flexible welding, assembly, and installation in tight spaces.
3 kg
692 mm
View CRX-3iA
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-10iA
1249 mm
View CRX-10iA
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
CRX-20iA/L
20 kg
View CRX-20iA/L
View CRX-10iA/L
Compatible Controllers
Painting
