Roboworld, LLC
Cobot Device
CRX Robosuit
By Roboworld, LLC Other
Roboworld protects robotic equipment from costly repairs and even more costly downtime. It’s as simple as that. From customized Robosuits and teach pendant bumpers to complete automation cell protection, Roboworld is the solution for everyday protection from the most vital operating environment on the planet — yours.
Device Features
A robosuit for a CRX robot provides a critical layer of protection that helps extend equipment life and maintain performance in demanding environments. Designed with versatility in mind, these suits can be tailored to meet specific application needs, incorporating features like water-resistant zippers and positive pressurization to guard against moisture, dust, and contaminants. With a wide range of material options—including Hypalon, Teflon, Isotherm, Norfab, and FR Vinyl—each suit can be optimized for durability, chemical resistance, or temperature control. Custom sound-dampening solutions are also available, and we can integrate customer-supplied materials when needed, ensuring a precise fit for any operational requirement.
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-10iA
1249 mm
View CRX-10iA
CRX-10iA Food Grade
CRX-10iA Food Grade
1249 mm
View CRX-10iA Food Grade
View CRX-10iA/L
CRX-10iA/L Food Grade
View CRX-10iA/L Food Grade
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-20iA/L Food Grade
20 kg
View CRX-20iA/L Food Grade
CRX-30iA
30 kg
1889 mm
View CRX-30iA
CRX-30iA Food Grade
CRX-30iA Food Grade
30 kg
1889 mm
View CRX-30iA Food Grade
FANUC CRX-3iA cobot
CRX-3iA
Ultra-lightweight collaborative robot weighing 11 kg with 692 mm reach, designed for fast, flexible welding, assembly, and installation in tight spaces.
3 kg
692 mm
View CRX-3iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
CRX-5iA Food Grade
CRX-5iA Food Grade
5 kg
994 mm
View CRX-5iA Food Grade
Compatible Controllers
CRX 10i A Paint Inspection
Inspection
M 800i A 60 Laser Cutting copy
Laser Applications
Machine Tending
CRX Handling Metal Block 1
Material Handling
Painting
