CR-35iB
The CR-35iB cobot lifts up to 50kg with a compact footprint, advanced sensors, and easy programming — ideal for tight spaces and heavy-duty tasks.
- Max Payload:
- 50 kg
- Reach:
- 1643 mm
Inbolt turns a standard CRX into a vision-guided cobot with two pieces of hardware: a wrist-mounted 3D camera and an industrial controller that runs everything on-premise.
Enhance productivity with the dependable FANUC CRX-20iA/L, featuring a 20 kg payload, extended reach, and user-friendly programming.
Food-grade collaborative robot with a 30 kg payload, hygienic construction, and intuitive wrist controls for easy teaching and deployment.
Ultra-lightweight collaborative robot weighing 11 kg with 692 mm reach, designed for fast, flexible welding, assembly, and installation in tight spaces.
The FANUC CRX‑5iA Food-Grade Cobot ensures safe automation in food & beverage with a 5kg payload, 994mm reach, and user-friendly programming.
FANUC robots & cobots deliver precise, repeatable adhesive dispensing for jobs from small glue tasks to large-scale automotive seam sealing.
FANUC robots deliver safe, precise finishing — cutting, sanding, polishing & more — with vision & force sensing to boost quality, speed & productivity.
FANUC paint robots, built in Michigan, automate coating tasks for safety, quality, and efficiency — ideal for hazardous and high-demand environments.
FANUC palletizing robots and cobots offer fast, precise, and safe automation for stacking boxes, bags, pails, or drums — boosting efficiency and care.
