SMW Autoblok
Cobot Device
MX-S Mechatronic Gripper Kit
By SMW Autoblok Grippers & Tools Includes CRX Plugin
The SMW Autoblok MX-S Mechatronic Gripper kit is a plug-and-play design for fast and easy setup for the FANUC CRX. It features Direct Tool I/O with no additional interface requirements. It mounts directly to the standard robot flange and plugs in directly on-board. The MX-S gripper is a self-locking Mechatronic gripper that retains its grip force and position even if power is lost.
Device Features
  • Plug + Work: Fast and easy setup
  • Grip Force up to 200N
  • Jaw Stroke of 8mm per Jaw (16mm Overall)
  • IP40 Protected
  • Direct Tool I/O: No additional interfaces required
  • Direct mounting to robot flange
  • CRX Plug-in on board
  • Simple control with CRX software
  • Self-locking & grip retention in case of power loss
  • Precise 2-jaw parallel gripping
All necessary parts in delivery of scope:
  • MX-50 Gripper
  • Universal fingers with double-prismatic ends
  • Plug-in for CRX software, connection cable to connect direct at the tool flange interface
  • User Manual
Use as a small parts gripper due to lightweight and compact design. Mechatronic drive with gripping force maintenance in the event of power failure. Use as a small parts gripper due to lightweight and compact design.
Stroke per jaw
8 mm
Weight
0.9 Kg
Communication interface
DIO
Power supply
IP40
Total gripping force
200 N
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-30iA
30 kg
1889 mm
View CRX-30iA
FANUC CRX-3iA cobot
CRX-3iA
Ultra-lightweight collaborative robot weighing 11 kg with 692 mm reach, designed for fast, flexible welding, assembly, and installation in tight spaces.
3 kg
692 mm
View CRX-3iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
Compatible Controllers
CRX 10i A Paint Inspection
Inspection
Machine Tending
CRX Handling Metal Block 1
Material Handling
