CRX-10iA
- Max Payload:
- 10 kg
- Reach:
- 1249 mm
The RIG Palletizer is a flexible, highly adaptable robotic palletizing system built for high-mix production. Powered by the RGS Full Stack software platform, it pairs a FANUC CRX collaborative robot with integrated vision systems to identify box sizes, correct misalignment, and verify accurate picking without the need for mechanical alignment tools. Customizable end-of-arm tooling supports top, side, and bottom pick products weighing up to 50 lbs. Mounted on a mobile cart with a 360-degree area scanner safety perimeter, the RIG rolls between production lines in under 15 minutes. Data and analytics stream to the cloud-based Control Center, giving operators on-demand access to production information from anywhere. Through the intuitive touchscreen HMI or Control Center, teams can configure pallet patterns, box dimensions, and jobs in a completely no-code environment.
Training: On-site and video operator & maintenance training included with integration. Integration: 2 days on-site, palletizing on day 1.
Enhance productivity with the dependable FANUC CRX-20iA/L, featuring a 20 kg payload, extended reach, and user-friendly programming.
Food-grade collaborative robot with a 30 kg payload, hygienic construction, and intuitive wrist controls for easy teaching and deployment.
Ultra-lightweight collaborative robot weighing 11 kg with 692 mm reach, designed for fast, flexible welding, assembly, and installation in tight spaces.
The FANUC CRX‑5iA Food-Grade Cobot ensures safe automation in food & beverage with a 5kg payload, 994mm reach, and user-friendly programming.
High-performance R‑30iB Plus Paint Controller with purge unit, boosting productivity, speed, accuracy, and safety for paint robot automation.
Compact and stackable R‑30iB Plus A‑Cabinet, ideal for industrial use, supporting up to 2 auxiliary axes in a space-saving design.
