Coherix
Cobot Device
Coherix 3D Adhesive & Sealant Process Control
By Coherix Sensors
Everything we do begins with our enabling technology: Coherix 3D™. It allows you to see in three dimensions with unmatched accuracy in even the most complex robotic adhesive dispensing applications. It is the new eyes of manufacturing, providing a clarity and depth never before achieved.
When combined with our powerful software, Coherix 3D is able to see, report, respond, and adapt. Right now, around the world, Coherix 3D’s inline bead inspection system has helped customers optimize their adhesive and sealant dispensing processes. How? By inspecting your most critical and complex applications. Or, going one step further, helping you adapt, improve, and get one step closer to perfection through Adaptive Process Control.
Device Features
Coherix 3D provides robust, real-time 3D in-line inspection and Adaptive Process Control, capturing data of how much and where the bead is located - 400 times per second per laser.
  • In-line robust 3D
  • Self-contained, around the nozzle solution
  • Bead location relative to part features
  • No added complexity to robot programming
  • No blind corners
  • Impervious to ambient lighting & part color changes
  • Quick & easy setup
  • Robot carried or pedestal mounting
CR-35iB
50 kg
1643 mm
View CR-35iB
CRX-10iA
1249 mm
View CRX-10iA
View CRX-10iA/L
CRX-10iA/L Paint
View CRX-10iA/L Paint
CRX-20iA/L
20 kg
View CRX-20iA/L
CRX-30iA
30 kg
1889 mm
View CRX-30iA
FANUC CRX-3iA cobot
CRX-3iA
Ultra-lightweight collaborative robot weighing 11 kg with 692 mm reach, designed for fast, flexible welding, assembly, and installation in tight spaces.
3 kg
692 mm
View CRX-3iA
CRX-5iA Cobot
CRX-5iA
5 kg
994 mm
View CRX-5iA
FANUC CRX-20/14A collaborative robot
CRX/20-14A
The FANUC CRX/20 – 14A is a compact collaborative robot with a 20 kg payload and long reach, ideal for palletizing, welding and machine tending.
20 kg
View CRX/20-14A
FANUC CRX-30/18A collaborative robot facing left
CRX/30-18A
CRX/30 – 18A collaborative robot delivers 30 kg payload, 1,756 mm reach, intuitive teaching and advanced controls for heavy-duty palletizing and handling.
30 kg
1756 mm
View CRX/30-18A
Compatible Controllers
R-50iA
View R-50iA
CRX 10i A Paint Inspection
Inspection
Painting
